format string to mmmmdd style
I need to formate decimal sting to mmmmdd style. mmmm is the integer . dd is exponent.
such as: 0.5 =5000-4(5000e-4)
100.3=1003-1 (1003e-1)
40.3=4030-2(4030e-2)
which function should I use?
Message 1 of 12
(3,952 Views)
Help me understand.
do you want a numeric with a displayed value "5000e-4" (txet.text property) or a string of the characters [5,0,0,0,e,-,4]
Message 2 of 12
(3,948 Views)
I need to conver a number to command whose format is mmmmdd. mmmm is the interger. dd is the exponent value
Finally I need 5000-1 which mean value is 500
Or 5000-2 which mean value is 50
Is it clear?
Message 3 of 12
(3,945 Views)
Do you want the 'command' as a string?
Message 4 of 12
(3,941 Views)
yes
Message 5 of 12
(3,937 Views)
Edit: Removed one primitive
Message 6 of 12
(3,935 Views)
Message 7 of 12
(3,928 Views)
Fancy. This one doesn't handle the leading zero:
Message 8 of 12
(3,925 Views)
I figured he would beat me to it-  I took 1 silly break to fill out my timesheet and -----
Message 9 of 12
(3,921 Views)
Thank you for your kindly help
Message 10 of 12
(3,916 Views)
