format string to mmmmdd style
BTW, where has the good explanation for the function of format into string?
what does mean "d"?
Message 11 of 12
(346 Views)
For a good explanation of the format into string function you can look in the LabVIEW Help (Right click on your format into string node and select Help). From that help page there is a hyperlink to the format string help (in the first line of the help doc) which gives an explanation of all the special characters. Or you can check out the online version of the help document.
Message 12 of 12
(335 Views)
