formula mathematical
No, If the original equation is valid for all z and all coefficients are coefficients (not functions of z), then is right. It is a standard procedure.
You can not find constant coefficients a, b to satisfy the following equation for all z: a*z+b*z^2=z^3.
Message 11 of 12
(359 Views)
This is especially true when you think of z as a delay, as it normally is in signal processing and control.
GCentral
Message 12 of 12
(343 Views)
