formula node bug?
   I can't figure out what I'm doing wrong with the formula node.  I tried this on both LabView 2011 and Labview 2013 version and got the same results.  Basically I want to past any numbers with a decimal to the formula node.  If the number is more negative than -1 then set the value to -1 and if the number is more positive than 1 then set the number to +1.  Anything else just return the input to the output.
This arithmetic works correctly when I use the LabView discrete "Select" function.  In the formula node I have this code:
if(Xin < -1.0)
   Xout = -1;
else
   Xout = Xin;
if(Xin > 1.0)
   Xout = 1;
else
   Xout = Xin;
Where Xin is the input node and Xout is the output node. It works well for anything over +1.  If you pass 1.5, you get 1.  If you pass 0.5 you get 0.5.  It even works for negative number greater than -1.  So passing -0.5 you get -0.5 etc.   The problem shows up when passing anything more negative than -1.  If I pass -1.5, I get -1.5 as the answer.  The Labview discrete select function method gives me the correct answer as -1 when passing -1.5.
I even tried to make sure that the input is casted to float just in case it got mixed up as an integer.  But the results are the same.  So either I don't understand the formula node syntax or there's something else going on.
float32 X =  Xin;
if(X < -1.0)
   Xout = -1;
else
   Xout = Xin;
if(X > 1.0)
   Xout = 1;
else
   Xout = Xin;
Message 1 of 12
(9,527 Views)
Accepted by patrick.chaopricha
Consider the X in= -1.5 case.
The first test sets Xout to -1.
Then the second test runs and sets Xout to Xin = -1.5.
Last test wins.
In LabVIEW primitives using the In Range & Coerce function might simplify things a bit and it would be very clear what you were trying to do.
Lynn
Message 2 of 12
(9,524 Views)
Ah, that makes a lot of sense!  I should probably use (else if) for the second test.  Using primitive case, this wasn't a problem since the result of the first test is passed to the 2nd test so the Xin value is actually the Xout from the previous test.
if(Xin < -1.0)
   Xout = -1;
else if(Xin > 1.0)
   Xout = 1;
else
   Xout = Xin;
 Or I could also do 2 formula nodes (if the test gets complicated enough).
Thanks!
Message 3 of 12
(9,518 Views)
What Johnsold mentioned, LabVIEW has very compact solutions for many common tasks
Message 4 of 12
(9,497 Views)
Thank you for the input.  I did have the "select" example in the code but it good to see other examples as well.
Message 5 of 12
(9,448 Views)
What's wrong about the Sign function which does exactly what you tried to implement? Smiley Very Happy
Rolf Kalbermatter  My Blog
Message 6 of 12
(9,428 Views)
Hmm .. sign function would work.  I don't remember seeing it in my pallette though.  I'll have to go back and look. I was using version 2011 and 2013.  That would be the simplest way to do it.
I was trying to implement something to basically force the spiral radius calculation to behave correctly.  I have found other ways to do it without using a formula node now though.
Message 7 of 12
(9,418 Views)
Hi Rolf,
the Sign() function isn't correct in this case as the requirement was:
InRangeAndCoerce is suitable here…
Message 8 of 12
(9,410 Views)
I also don't have the Sign function in 2011 version of LabView.  I wasn't able to check the 2013 version.  Is the output can only be -1, 0, and 1 with the Sign fuction?  If so then GerdW is correct that it doesn't meet my criteria since I wan the original number to come through if it's not greater than either signs.
I attach the picture from my 2011 LabView Comparison Pallette.  Maybe I can access the Sign Function in a different way?  It might be handy for other uses.
Message 9 of 12
(9,370 Views)
The sign function is on the numeric palette.
Message 10 of 12
(9,360 Views)
