formula node error
Error using formula node with non-linear fitting VI.
I am using LV 2011 on windows XP.
Using Nonllinear Curve Fit.vi.  I have used this before successfully.I am using the "formula string" instance of this polymorphic VI.  When I run my program using the formula string "b0+b1*x", it runs fine and give sensible results.  When I use the formula string "b0+b1*x+A1*x^2" I get the error message "Error -23083 has occurred at an unknown location. Analysis: Bracket problem at the end."
Attached screenshots show part of the block diagram that wrorks (lv0.bmp) and ppart of the block diagram that does not work (lv1.bmp).
Thank you.
(5,413 Views)
You are doing a bit exclusive or with the ^ operator. If you want exponentiation, you need to use **.
(5,407 Views)
Thank you Dennis. It turns out the "caret" ("^") operator is OK here, and is raising a number to a power, as desired.  The problem was that I used an uppercase letter in a variable name.  Not allowed!  Nor can variable names have have two letters, although that wasn't the problem in my example. (It was a problem in some of my other attempts.)
(5,378 Views)
