size of a table in an access database
hi,
i try to know the size of a table in access database,then i would to transform it to a string value,but i don't success.
i attached a jpeg image of my code.
in the concatenated string must appear "rapportx.png" where x represent the size of the table
(2,608 Views)
Accepted by topic author iman
You should use "Number to decimal string" to convert the number to text.
Please note also that the "Array size" returns a 2D array in yuor case: so you have two dimensions.
Last, but not least, to count the number of records, it wuold be more efficient to use the sql count() function:
http://www.w3schools.com/sql/sql_func_count.asp
Marco
(2,585 Views)
thanks, i split the 2D array then i use number to decimal string ,it work
(2,581 Views)
