[fpga] Faster communication between FPGA and real-time host
I am trying to achieve a loop rate of 2.5 kHz on the the real-time vi. While the inner current control loop on the FPGA is running at a loop rate of 8 kHz.
  • I have used a timed loop and instead of merged signal function, I have used a cluster block for the charting. This has led me to achieve the loop rate of 2.5 kHz consistently. I am using a timed loop to do the same. I have attached my code below. Can you go through my code once, and if possible can you suggest how I can optimize it further?
  • When I replace the timed loop with a while loop, and benchmark my code, I can observe a lot of jitter being present in the code. I have used the benchmarking project available in one of the LABVIEW examples to provide a timing analysis of my code. The amount of jitter present in some iterations is extremely high. Can you please shed light on why this is the case?
Message 21 of 21
(281 Views)
