fpga target
j'ai instalé labviaw2012 et labview fpga module mais j'ai pas trouvé target je ne sais pas ou est le probleme et comment je peux trouvet cette option parce que je veux travailler sur fpga, merci en avance pour m'aider et voila pieces jointes
Message 1 of 9
(4,489 Views)
Bonjour scream,
Excusez-moi, mais je ne parle pas bien francais.  Tu as instalé LabVIEW et apès instalé LabVIEW FPGA ou LabVIEW FPGA et ensuite LabVIEW?
Kind Regards,
Marshall B
Applications Engineer
National Instruments UK & Ireland
Message 2 of 9
(4,473 Views)
j'ai installé labview et aprés labview fpga module   et merci pour ton aidé
Message 3 of 9
(4,444 Views)
You'll also need to install the drivers for your FPGA board (R-series, cRIO, etc).  Did you install any of the device drivers?
Message 4 of 9
(4,433 Views)
yes I installed this device but I dont have target for FPGA can you help me and thank you
Message 5 of 9
(4,399 Views)
Open Measurement and Automation Explorer, and look under Software.  You should have LabVIEW and the FPGA toolkit, as shown in the attached screenshot.  You should also have NI-RIO, also visible towards the bottom of this screenshot.  If you have both of those, try reinstalling the RIO device driver, and make sure that you include support for the LabVIEW version you are using, as shown in the second screenshot.
Message 6 of 9
(4,375 Views)
thank you in advance  and that the measurement&automation page look under software you can tell me what i need to use FPGA and software what i need for to install because i dont have (FPGA TARGET) in my labview;  thank you so mutch for your help
Message 7 of 9
(4,361 Views)
Message 8 of 9
(4,360 Views)
You need to install NI-RIO (Reconfigurable IO) from the Device Drivers DVD.  Make sure you include support for LabVIEW development, as shown in the screenshot in my previous message.
Message 9 of 9
(4,349 Views)
