fpga
engt Hello.
One of the engineers in our R&D department was able to replicate the problem you are seeing by changing his regional settings on his computer to Turkish.
Right now, the only way to get over this error will be to transition to an English version of the Operating System as we do not test the module on all languages.
Please post and let us know if this helps.
Efosa O.
NI-AE
Message 21 of 23
(2,086 Views)
Hi Efosa,
You are right but there is a amall difference. The language version is not important.
To eliminate this problem, setting the language to English (USA) from the Control Panel / Regional Settings. I am still using a Turkish Win XP SP 2 but
I set the keboard language to English and the cRIO works fine.
Thank you for your effort for solving my problem.
Now I am very happy without this problem
Also thanks Joseph and NI FPGA team.
I hope this would be a sond reference to NI and customers....
Message 22 of 23
(2,081 Views)
Hi
I have the same problem!!! Except that I'm running Windows 2000!! ANd this error has appared since i'm under LV 8.2.
I've tryed to change regional to english it doesn't work.. 😞   I will try to put it in englisk (usa) to see.....
here is the error message :
Mapping design into LUTs...
ERROR:MapLib:661 - LUT4 symbol "mytop/n_413/n_320/n_314/n_311/_n0002<0>1"
   (output signal=mytop/n_413/N32) has input signal
   "mytop/n_413/n_320/n_314/n_306/xeqy<0>" which will be trimmed. See the trim
   report for details about why the input signal will become undriven.
ERROR:MapLib:661 - LUT4 symbol "mytop/n_413/n_320/n_314/n_311/_n0002<1>1"
   (output signal=mytop/n_413/N30) has input signal
Error found in mapping process, exiting...
Errors found during the mapping phase.  Please see map report file for more
details.  Output files will not be written.
Design Summary
Number of errors   :   2
Number of warnings :  11
ERROR:Xflow - Program map returned error code 2. Aborting flow execution...
Message Edité par julesjay le 01-17-2007 08:46 AM
Message 23 of 23
(1,616 Views)
