fpga
Hi guys,
My program used to work but after I added another while loop for updating the input of another loop, the program didn't work well any more. I attached the file and thanks for the help!
Nick
(3,064 Views)
Hi Nick,
do you actually stop that loop?
(3,063 Views)
Hi GerdW,
Thank you for your reply.
I just tried to run the program and didn't click the stop button for the small while loop.
But now I added a local variable to get the out loop value of the small while loop and use this local variable as the input in the big loop instead of directly connecting them.
And I also set the stop of the small loop to be false this time and we'll see what happens.
Thanks!
Nick
(3,060 Views)
Problem Solved!
Thanks a lot!
Nick
(3,049 Views)
