how can I programatically change a reference to an item in a cluster?
Hello!
I'm trying to programatically change the text background color of the elements in a large cluster.
I'm using LabVIEW 2010 SP1.  Attached is a test vi that I'm expermimenting with.  The test cluster has 6 elements and the final cluster will have 140.
All elements will be the same data type.
Based on the rate of change of the element value, I have to change the background color.
Instead of creating a reference for each element in the cluster (as in my test vi), I'm looking for a way of changing the reference programatically.  Is there a way?
I'm also considering building an array of references as a brute force alternative but I would like to see if there is something more elegant / efficient first!
Am I making sense?
thanks,
mike
(2,503 Views)
Mike,
You can get references to the elements inside the cluster from the cluster reference using property node: All Objects[].  This is an array of references to the controls inside the cluster.
Another way which might have advantages is to put a color box indicator behind each numeric.  Color the numeric backgrounds Transparent.  Then write the color to the color box.  I did a quick modification to your VI to show this possibility.  I did not adjust the size of the color box to match the numeric to emphasize what I did.
Lynn
Another note: If any of your users are color blind some of the combinations (black on red) might not be very visible.
(2,491 Views)
Accepted by topic author mngrigg
Hi Lynn!
You gave me the clue I needed.
The AllObjs property node was the answer but it needed the "to more specific class" type conversion to go along with it - see attached.
Thank you very much!
mike
(2,483 Views)
