frequency synchronization on the USRP RIO
 hi everybody;
-hardware: USRP RIO 2952
-overview of the project is to transmit and receive a text using labview comms and USRP RIO 2952,I already built the transmitter and the receiver.
 my question is that:
-I want to transmit and receive using one of the two channels of the USRP RIO,but we found that there is a frequency offset (shift) between the transmitter and the receiver.
-we try to measure this shift but we found that this shift is not fixed  it is variable.
-because of this problem we cant receive the transmitted signal.
-is that  a problem in the hardware itself.
thanks a lot.
(2,671 Views)
Accepted by topic author DOHAAACB19619
What kind of frequency shift are you seeing? -- a range would be helpful in terms of clarifying if this is expected behavior or not. In general, it's important to keep in mind that all our USRP devices are uncalibrated/unverified -- this means that we can't guarantee that you'll be seeing the exact same results every time you run a test on the device. Have you been able to make this work successfully on another USRP-RIO device? Are you using an example program in LabVIEW Comms? If so, which one?
Let me know!
Sunayna R.
Applications Engineering
(2,623 Views)
Hi  sunaenae:
I already test the system(TX-RX) on another USRP-RIO and found that the problem still exist and no change,can you help me solving this problem,I am sure that there is a solution for this problem.
thanks a lot;
(2,578 Views)
