from labview to excel:table and graph customized
Hi
I want to get this table in excel and in front of each row a graph drawed using just the value of E1,E2, E3, E4, E5 ....E10 ,and in the table ,for the columns M1 M2 ....M10 the have to contain either yes or no ,if yes the cell has to be green if ni the cell has to be red.
i'm wondering if there is a real solution to solve thoses 2 problems
(3,435 Views)
Hi achfire,
 There are many questions i need to ask you:
 q1)Whether you want to export this table to excel sheet or you got this table from excel file?
 q2) What do you mean by " in front of each row a graph drawed using just the value of E1,E2, E3, E4, E5 ....E10"?
 q3)What is the condition for M* columns to show red and green colors?
SrikrishnaNF
Srikrishna
(3,406 Views)
1-i want to export this table to excel sheet
2-because those values are numeric and each one represents elapsed time in a test ,so i want to get a graph from thoses values for each student,and in front of his row.i think i must have big rows so the graph will be clear
3-it's about a maintain,so it has either true or false(booleen),if it's true>green otherwise > red
(3,398 Views)
Greetings achfire
To move the table contents as well as generating the graphs, you may want to consider the possibilities outlined in this article.
As for painting the cells from columns M1 and M2 green or red, you have to check the condition manually and then apply the format change.
Let us know if you have further questions.
Warm Regards,
Luis J.
(3,369 Views)
thanks a lot for your suggestion.
i decided to change the way of getting graphs,it's not really evident.i'm now thinking to get each row in a different worksheet,so the data and the graph for each row will be in a great size.
if you know how i can program each row in it's specific worksheet
(3,352 Views)
Hi achfire
The way to change the active worksheet would depend on the implementation that you chose. For example, check this document on using the Report Generation Toolkit.
Other solutions are outlined in this forum:
Let us know how it goes.
Luis J.
(3,331 Views)
