front panel color changes back to default
Hey!
I have this problem coming with my LV8.0 that whenever i print the front panel ,it color changes back to the default gray .Whereas i want to make my panel white .Any solutions?
Message 1 of 31
(5,246 Views)
Does the panel actually change color back to gray or is just the printout greyish?
(A lot of modern color printers have automatic color matching, which is often inappropriate for cartoonish things such as front panels. Try to play with the printer settings.)
If you just want plain b&w, you could also disable the "color/greyscale" option in the LabVIEW print options.
Message 2 of 31
(5,235 Views)
This a known issue fixed in LabVIEW 8.2
A little more background:
On a print (or getImage method) transparent parts are converted to gray.
Ton
Message Edited by TonP on 04-28-2008 07:59 AM
My LabVIEW Ideas
Message 3 of 31
(5,218 Views)
Hi  everybody !
 Can you help for me . l can change color of front panel, For exam : when l open new VI, usually you see  brown color. But  l do not want have brown color. How can l do change color. Thank you very much
Message 4 of 31
(4,959 Views)
Hi everybody !
Can you help for me .  l can changes color of front panel . For exam : When  l open new VI, usually have brown color. But l do not want, when l open new VI. l want have another color.  How l can do, Can you help for me. Thank you very much
Message 5 of 31
(4,957 Views)
Message 6 of 31
(4,951 Views)
hiiiiiiiiiiiiiii !
This is 2 file, but l have some question .
l read some information about: Brushless Permanent Magnet AC Motors   then  have some information in document.
     Slip-ring Induction Machine: 415 V, Y, 3 ~, 11 A, 1410 rpm, 5.5 kW, cos f = 0.85, 50 Hz, ROTOR: 170 V, Y, 22 A.
But l can not find in file labVIEW. Thank you very much when you explain for me.
Message 7 of 31
(4,946 Views)
Message 8 of 31
(4,943 Views)
Why did you post so many of the same message?
Do you want to set your default color for new VI's, or just change the color of a VI?  To change colors on the current VI, just shift right click on the front panel, and pick the paint brush.  Right click again to get to the color picker.  To fix the default colors for all new VI's, go to Tools menu, Options, Environment, then Colors section.
As for your message where you list motor nameplate specifications, I have no idea what your question is.  I don't know where you got your .doc file or .llb file in your other two messages.  All I can say is read the word document and follow it line by line.  It seems to be some sort of educational instruction sheet.
Message 9 of 31
(4,896 Views)
If you want to change the color of the front panel from one color to another manually, then go to "Tools->Options->colors" and then change the color of the front panel to whatever color you want.
Guru
Regards
Guru (CLA)
Message 10 of 31
(4,891 Views)
