front panel color changes back to default
hoa than wrote:
Thank you very much you to reply me. l am sorry because my English not good. I am VietNamese. Red color is high limit. White is  temperature (t )  and green color is  low limit.
You say here that the temperature is represented by the white line but you later say you want to see the green line change. However, this green line is NOT the temperature data, it is the low limit. Since you said you do not change the low limit, then this line should not change.
Message 31 of 31
(455 Views)
