front panel of a vi pops up when i start my top level vi how can i stop this
i have a vi that whos front panel should display when the user clicks a front panel button(test instructions),
however this vi pops up when i run the top level vi. I can manually close the vi, but how do i stop this?
i tried modifying the Sub VI Set up properties, but that doesnt work.
(2,799 Views)
So you went to Customize Window Appearance under VI properties and neither Show front panel when called or Show front panel when loaded was checked?
(2,792 Views)
Also check the SubVI Node Setup (right-click on the subVI within the main VI).  It is possible to set a single instance of a subVI to show the front panel when called this way.
(2,786 Views)
Accepted by jknapp
Hi jknapp,
As egraham has pointed out, you can customize the window appearance of your sub VI from the VI Properties.  If you go to File » VI Properties, then under Category select Window Appearance and then Customize..., you should be able to control how the sub VI appears.  Hope this helps!
Taylor G.
Product Support Engineer
www.ni.com/support
(2,763 Views)
thanks that worked!
(2,756 Views)
