ftp put file
How can I transfer my file to the web server. I use the ftp put file.vi  when I run it ,the error code is 15501.  says "there is not file name".
Thanks in advance.
(2,894 Views)
double check the path to the file you're trying to upload, make sure it is a valid path
also, it'll help if you attach your vi ^_^
(2,884 Views)
