hi
help !!!
im using labview 6.1 to open a file write date to it then close it.
then i open it again do the same and then close it.
this vi is called from an event handler.
once i have quited the vi and am sitting in the time out part of the event handler i try to open the file i wrote to but am advised that its locked and that i can only access it read only.
if ive closed it this shouldnt happen should it?
