file locked for edit after close
hi
help !!!
im using labview 6.1 to open a file write date to it then close it.
then i open it again do the same and then close it.
this vi is called from an event handler.
once i have quited the vi and am sitting in the time out part of the event handler i try to open the file i wrote to but am advised that its locked and that i can only access it read only.
if ive closed it this shouldnt happen should it?
(2,436 Views)
are you sure you closed all the references to the file?
it'll help if you post your vi ^_^
(2,424 Views)
