generate and control voltage
I want to generate and control voltage (0 to 10) (V) using ni-9269. I did it easly with  alhabeeb_0-1724230249442.png. How can I do it by using alhabeeb_1-1724230311806.png
(966 Views)
Hi alhabeeb,
I did it easly with DAQAsisstent. How can I do it by using DAQmx functions?
Open the example finder and look for all those DAQmx example VIs!
Did you already read this article?
(950 Views)
Thanks, but all examples didn't mention what I need.
(937 Views)
Accepted by topic author alhabeeb
Hi alhabeeb,
Did you examine these examples?
Which part are you interested in and what is missing in the example VIs?
(924 Views)
Thanks I got it.
(898 Views)
Don't forget that you can also convert your DAQ ASSistant to DAQmx code after you get it set up.  Right-click and you will find options to open its front panel or convert it to DAQmx.  It's a good way to transition into real DAQmx code as you're learning.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(887 Views)
Thanks for the info.
(849 Views)
