generate mouse click on window
is there a way in LabVIEW (2010) to programmatically generate mouse clicks on other windows? I want to automate some things outside labVIEW, just click on a third-party window.
the second question goes in the other direction. Is it possible to capture a screenshot of the other window?
MB
(2,639 Views)
Hi mitulatbati,
                     Which is the thirdparty window that you are specifying?
However in the "event structure" area there is the option to have responses fired when mouse clicks occur; controlling both right and left mouse clicks. This isn't always the most pleasureable way of doing things, because it refers to any click.
Also refer the link below:-
http://digital.ni.com/public.nsf/allkb/9BB3211F3469623649257360000E272C
Thanks as kudos only:)
(2,628 Views)
