generate pam
I have recently bought the modulation toolkit.
I need to modulate a Sine wave to PAM. There is a vi called Modulate PAM. But the problem is that the information to be modulated, has to be a bit stream. So, how do i convert a sine wave to a 1D array of numeric (byte [8-bit integer (-128 to 127)]?
I am using the si Simulate signal to generate the sine wave.
Greetings
Message 1 of 16
(4,860 Views)
I am attaching the file i have been working on.
Greetings
Message 2 of 16
(4,868 Views)
Hey,
You
Message 3 of 16
(4,829 Views)
Hey,
You can
Message 4 of 16
(4,829 Views)
Hey,
You can do
Message 5 of 16
(4,829 Views)
Hey,
You can do this in
Message 7 of 16
(4,829 Views)
Hey,
You can do this i
Message 7 of 16
(4,829 Views)
Hey,
You can do this in a couple of
Message 6 of 16
(4,829 Views)
Hey,
Message 10 of 16
(4,829 Views)
Hey,
You can do this in a couple of steps.  The o
Message 11 of 16
(4,805 Views)
