get maximum value in a field using SQL query
I'm a little late to the party, but want to add this for posterity.  You can use the DB Tools Select vi to get an aggregate from a table by putting the aggregation in the table name.
Jim
Message 11 of 19
(3,662 Views)
That is not a very good practice if you ask me. If you go far enough under the hood, you will find that you can even put conditions (WHERE ..., ORDER BY ...) after the table name too and it will work. But just because you can doesn't mean you should.
And for the record, the easiest way to accomplish this IMO? Add "ORDER BY [column name] DESC" as the condition and take the first result. Boom, done.
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 12 of 19
(3,651 Views)
One could also execute SQL like this:
SELECT * FROM MyTable WHERE MyField=(SELECT Max(MyField) From MyTable);
Message 13 of 19
(3,644 Views)
Wouldn't 'SELECT Max(MyField) From MyTable' yield the same result?
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 19
(3,627 Views)
This may give you max(id), but not solve the problem. The problem is getting the whole row identified by max(id).
Message 15 of 19
(3,621 Views)
No.
Your solution only returns max(MyField).
The question was for the complete row for max(MyField), which is what the query from @drjdpowell will return.
Message 16 of 19
(3,616 Views)
I think you mean 'SELECT *, Max(MyField) From MyTable', which gets all the fields of the maximum row.
It depends if there is more than one row with the maximum value, in which case your version will only get one row, but the first version will get all such rows.
Message 17 of 19
(3,613 Views)
'SELECT *, Max(MyField) From MyTable' is quite non-standard SQL. Which database is this?
Message 18 of 19
(3,594 Views)
That's SQLite: https://www.sqlite.org/lang_select.html
It may not apply to other DBs.
Message 19 of 19
(3,587 Views)
