get method's diagram
Hi everyone !!
I'm a beginner programmer in Labview 2014.
I display data into a waveform chart. I'm just asking if it's possible to get the diagrams of the methods that apply to my chart. I need to modify one of them according to my customer requirement.
(3,633 Views)
Your post doesn't really make any sense - can you perhaps show a screenshot of what you want to do / are trying to change?
In addition to changing the style of the graph (e.g. modern, classic, silver), you can recolour parts of the graph and there are lots of properties that allow you to configure the graph programmatically - but without knowing what you are trying to do I can't really suggest anything more than that.
(blog)
(3,615 Views)
I am using the method " export to excel" which export data into a temporary file without saving it. I am trying to export data from a chart  into an excel file with these options :
- save the file in a specific location on user's action.
- save automatically and periodically the data in the same excel file to clear the buffer (improve memory)
That's why maybe the method's diagram of "export to excel file" could have been helpful.
(3,589 Views)
I still don't understand what you mean by the "method's diagram".
(3,575 Views)
Accepted by ThibaudP
Hi Thibaud,
There is no "block diagram" for this method node. Point.
It's the same like with any LabVIEW function (like BuildArray or a simple Add): you will not get a block diagram. Those functions are provided as they are: Use them or don't use them…
Use the FileDialog to ask for a filepath. Save the file when the user presses a button.
When it has to be an "Excel" file you should think about RGT functions or ActiveX to remotely control Excel.
Otherwise use simple spreadsheet files and functions like WriteToSpreadsheetFile.
(3,568 Views)
