get sheets name of excel file
Hello!
I come back to you after our last discusssion to show you my work advancement, I attached the calling VI ( the main , it's not already complete) and the sub vi " reading data from excel)
I did'nt split the sub vi into 2 modules,, I keep the whole VI to get the sheets and read excel data, but I added in the sub vi a user event with dynamic events anabled, to read values of selected sheets, i succeed in getting data in the main vi and get also the corresponding Plots. But sometimes when I select a sheet  i don't get the values of that sheet but of the sheet selected just before,( which means that the control value is not updated at each run time) and I didn't understand why! please try to run the VI that i attached to know more about the problem and how to solve this
I thank you in advance and I welcome your notes and comments about the 2 attached VIs to make them better
Message 31 of 31
(794 Views)
