get username in exe
I am trying to get the current username in an application.  Using a property node to pull the username works great in the development environment however once the vi is build into an exe it fails.  Also tried system exec to pull the environment variable %username% and this as well works great in the development environment however fails once build.  Is there a solution to this? (running LV 2012 on windows7)
(3,280 Views)
Accepted by topic author Isereau
The example below works in the built exe:
http://forums.ni.com/t5/LabVIEW/get-user-name/td-p/634611
(3,274 Views)
Nice link.  But with a win 7 OS its probably easier to just do this
Then I read Derriks comment on the other thread Smiley LOL Do that instead
(3,266 Views)
An its probably easier to represent a year with 2 digits instead of 4 but that's how you get Y2K, or whatever.
I'd recommend the DLL call, more compatability.  Still tied to Windows of course.
(3,259 Views)
