get waveform subset
Hi friends,
 I want that the signal between maximum and minimum values of the graph 2 is cut and  see the signal in graph 3.  x value  corresponding to maximum y value  is different in the graph 2 and 3. I want that x values of the graphs is the same. what can I do?
I attached to VI
(2,835 Views)
Why not code exactly what you stated?
Take a subset of the signal by finding the location of the maximum and minimum values.  Then plot it on the new graph.
Copy the xscale values fromt the property nodes of the first graph and set the property nodes of the second graph.
LabVIEW ChampionLabVIEW Channel Wires
(2,806 Views)
Thank you
(2,800 Views)
