getting last saved values
In my application I obtain 1 set of values by pressing a button. Another portion of the program uses these values to perform an action. Now if I stop the program and rerun it then these values become default values.But I want to use the last saved values each time I run the vi. How can i do this?. Is the only way to do it by saving in a file or is there anyother way
(3,014 Views)
If you want to build an application of your code then yes, you will need to save the files to a file. If not you can save the values in the VI file itself - just use an invoke node on the VI and use the make current values default method and save instrument method.
For built applications you can make your own setup IO solution or you can use functionality in e.g. the OpenG toolkit (see:http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000DF730000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_TIER_0=0&USEARCHCONTEXT_TIER_S=0&USEARCHCONTEXT_QUESTION_0=save+all+control+values&USEARCHCONTEXT_QUESTION_S=0).
If you want to save more than just the values have a look at the Property Saver Toolkit by Konstantin Shifersh
teyn:
http://www.kshif.com/lv/index.html
(3,014 Views)
