I have created a vi with a flowmeter
I have created a vi with a liquid flowsensor control in it. I have to store the valeu what is comming out, and make a control if the flow is to low that the machine is switched off.
After the test of the machine, i have to create a report with, duration, flow and pressure in.
So this means, all the stored valeus of the flow have te bo placed in to the report with a time and date.
How to do this.
See attached files.
Tia, William
Software: Labview 6.1
Hardware: Fieldpoint
Running with Labview 6.1
Fieldpoint hardware
(2,620 Views)
Hello William,
Thank you for contacting National Instruments.
You might want to look at some example VIs for Fieldpoint. Go to Help >> Find Examples. In the Browse tab, select Directory Structure. Double click on the Fieldpoint folder. Then double click on the getting started folder. There should be some examples listed there.
I am posting the Analog Input and Output example VIs. These show you how to read values from a sensor and write values to a control. There will need to be some kind of comparison and perhaps a case structure to output an off command to your machine.
Let me know if you need more information.
Sean C.
(2,620 Views)
