standard report vis fail (error 1) after report toolkit loaded
Labview 6.1 report vis will not work (when dealing with standard report types) after loading the report generation toolkit 1.0.1. This is depite fixing the known issues found in the knowledge base. ie replace automation open with automation close in font style vi and recompiling the vis.
Running the text report example.vi included demonstrates the problem. Error 1 will be returned.
A sub vi in this called tables.vi appears to have 4 automation close vis two of which are inside for loops. I think these need to be outside of the loops? This then transfers the problem to the set font.vi which then returns error 1.
(2,662 Views)
avip,
Can you please provide the exact error message that you are getting? Also, have you opened up the VI causing the error and found exactly where it is happening (which property or method)? This will help us find this error much easier because I cannot reproduce the issue.
Once the toolkit is installed and the errors are fixed, we have not had any further issues with the examples.
Randy Hoskin
http://www.ni.com/ask
(2,662 Views)
I have the same problem. I am using LabVIEW 6.1 and Microsoft Office 97. I have installed and reinstalled the Toolkit. Whenever I try to run ANY sample VI's that come with the toolkit (by going to "FIND EXAMPLES"), none of them run. The ERROR LIST says that none of the subVI's are found. Why are these subVI's not being found? I see that they are there. Is there a directory error? Both LabVIEW and the Toolkit were installed in their default directories. The Toolkit is in C:\Program Files\National Instruments\LabVIEW 6.1\vi.lib\addons\_office
Advice Please?! I have a sample screenshot.
(2,662 Views)
