labview and Eagle pc104 card install Problem
Hello
I have problems to install a PC104 eagle card in labview6.0
Afer I Install the the eagle card on the computer.
(It works fine, and was installed proper, that tells me also the systemconfig)
and than
I have install the "LabVIEW� Interface Driver For EDRE"
I cannot find it in labview or labview can not find it ?
I dont know how I can install it in Labview.
Should i install the card in Labview or should labview see the card automatically ?
Can give me someone some hints or a desciption what I have to install first .......
I make it like this:
1. Installing Eaglecard in the system
2. Installing Labview 6.0
3. installing "LabVIEW� Interface Driver For EDRE"
-> now labview do not find the card and I find no optio
n to activate the card
thanks
Michael Haas
(2,567 Views)
According to the Eagle web site, there are "plug-in compatible" VIs installed. These new VIs would have to be used instead of the normal daq functions. Just for grins, I ran the install program from Eagle and it put them in the vi.lib folder. It did not automatically update any of the palettes (in 6.1) but the .mnu files are there so you can easily add the functions where you want.
(2,567 Views)
