getting started with ni hardware
Hi everyone,
I am using NI hardware for the first time.Are there any video tutorials and pdfs which will tell me information about them?
for example NI RIO, PXI, PCI. Their functions and how to use them?
I have used compact DAQ by reading on NI site but could not find topics on listed hardware.
Please help
Thank you.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,258 Views)
Hi Gaurav,
NI-RIO, PXI or PCI are just platforms or buses! It would be interesting to know what kind of e.g. PCI products (DAQ, FPGA, Motion, Instruments Bus, etc.) you're using.
Anyway:
1. Watch this: Getting Started with NI Products
2. Read the user manual of the product you're using.
3. Go to the main website of the product you're using. You'll find usually addtional help.
Luca
(3,254 Views)
One really nice thing that NI added a while back was the help in Measurement and Automation Explorer that shows how to attach the sensor to the Daq card. If you click on the measurement and automation Icon.
20123iEC012557552353C8
The program starts. Click the DaqMX Global Virtual Channels and add the type of device that you want to add. It will take you through a few steps then it will show you how to connect to the device.
20125i91785846EB51E333
Tim
GHSP
(3,239 Views)
That connections diagram is a nice faeture!
Another one that I use to get started starts at the same screen but a tab over where you can use your task in MAX.
If you go and save that task you can then go to LV and...
1) Drop a DAQmx task and choose the task you saved in MAX.
2) Right click on it and choose "generate code and configuration"
LV will generate all of the code required to match your config in MAX.
At that point you can re-write it correctly Smiley Wink and ge the same results you saw in MAX.
Ben
(3,228 Views)
Hi everyone,
Thank you for your help.
Gaurav k
CLD Certified !!!!!
(3,196 Views)
