getting the label from a radio selection in a radio buttons box
I am using a radio buttons control, with four radio selections in it.  I understand that this is an enumerated type, so the value is a "number."  When you wire that control to a case statement, the case is auto-populated with the labels of the radio selections.  Is there a way to capture the label of the button which was selected?    I am using LabVIEW 8.0 for this project.  Thanks in advance for your time.
(2,369 Views)
Accepted by bjstaff
Hi bj,
just use a FormatIntoString with format specifier "%s"...
(2,368 Views)
I figured there was an easier way than creating an array, and using the value to select which one from the array.  Thanks.
Brian
(2,364 Views)
