global variable
Dear All
I create a project in Labview with couple of VI's. I use a modbus tcp ip protocol to read registers from PLC controlers and the tcp open blok  . In the main screen i create a Menu with password  and username and i want to use this menu for changing the ip adresses of the other VI's. I made this task with global value but when i change the value the other VI work fine but when i close the windows and when i open again the global variable is empty. My question is how can i store the new value ???
(5,309 Views)
Hi bochev,
usually values are stored (for later re-use) in files...
Global variables hold their value as long as the containing VIs stay in memory. When you close all VIs you also forget about the global variable.
(5,301 Views)
ok thanks but do you know  any algoritm for storing values in variables after closing the VI's and the program..... and somethimes when it's needs to change the value with newone and then the new value will store again or there is no such function. Because in C; dotnet and other languages is different. You can store , change variables in any screen,menu etc.
(5,287 Views)
Hi Bochev,
as said before: when you want to store values to be available for the next programs run you should use files. LabVIEW provides a full palette of file functions...
And I do think other programming languages will handle ths problem the same way.
(5,280 Views)
(5,274 Views)
Accepted by BOCHEV
Hi Bochev,
yes, it's all possible...
(5,271 Views)
Use the Example Finder and examine the use of the Configuration File palette.
Jim
(5,265 Views)
