go from strings of bits to single byte (best practices?)
I'm looking for a more eloquent way to perform the conversion:
  • Multiple strings of bits to a single byte.
  • Single string into byte array representing the value of the number
See the VI for a functional but not scalable example.
Each string will have a value of 0 or 1, and they will be converted into a single byte.
I'm surprised there isn't a native function in the conversions section that allows a user to do this.
I would like to change the conversion into a function with the following inputs:
  • any number of bit strings
Output:
  • Byte or word
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(3,599 Views)
Okay hows this.  If you know each string is only going to be a bit, check to see if the string is not a 0, then you have an array of booleans to turn into a number.
(3,582 Views)
Accepted by eximo
I'm on LabVIEW 2012 and I can't open your VI, nor Hoovahh's modified version, so perhaps I'm posting exactly the same thing, but does this snippet do what you want?
(3,559 Views)
That is more elogant than what I have
-Regards
eximo
Neuronetrix
(3,543 Views)
