go to top in front panel
hello, i have a front panel with scroll bar. front panel is too large, i have some valve on top and control on the bottom of the front panel, i wanna go to top of the front panel when i press a boolean in the bottom of front panel to show the valve indicator. i waas looking around and found the widow bound option. but i cant figure it out how can i do that.
i dont wanna chage the window size, i just wanna go to a certain grid of front panel (and zoom it if its posssible).
hope i explained it properly. thanks
(2,731 Views)
Accepted by grasho
You need the origin property for the pane on the front panel.   Like this:
Zooming is not possible.
(2,722 Views)
thanks for that.
(2,710 Views)
Small hint:  You can either right-click on a scrollbar of the FP and Create->Property Node->Origin or drop a Property Node on the BD and Link To Pane->Pane to get at the property more directly:
(2,704 Views)
