gpib interface is missing
I have already installed the VI package manager. But I can't find the Express VI Structured Error Handler via Strg+space. Where can I find it?
I have the Labview Tools Network from JKI VIPM but when I search there for GXML which is required for the Error Handler it can not find it....
Message 11 of 16
(2,619 Views)
when I use clear errors, I need to build every time the .exe to check right? because generating reports is working in the development env. but not in the exe.
Message 12 of 16
(2,609 Views)
I asked NI to help me what's wrong with the .exe. I'm still waiting and will post the solution when I have it.
Message 13 of 16
(2,580 Views)
clear error function in the New Report.vi under NI_report.lvclass didn't work... the error is in the .exe still there.
Message 14 of 16
(2,564 Views)
Accepted by Susanne1709
I got the solution from NI.
I need to create a new Virtual folder, add Folder (Snapshot) and there I must add the reports templates for Excel. The .exe wasn't able to access to these templates, therefore the error 7 has occured. When I build the application, I need to set this new folder as "always included" under "Source Files". In "Destinations" I need to add a new folder with the same name. Most important is that I enable the option "Preserve disk hierarchy" for this folder and "Set destination for all contained items" to this folder under "Source File Settings". Now it's working Smiley Happy
Message 15 of 16
(2,522 Views)
Hey, thanks for the update, and BIG thanks for marking the problem as solved - AND for providing the solution.  The reason why this is so important is that someone having similar issues in the future can benefit from your experience.  🙂
Bill
CLD
(Mid-Level minion.)
Message 16 of 16
(2,504 Views)
