graph multiple inputs
hi
I am taking 4 inputs from a daq and i need to graph the 4 inputs on one graph. I tried to enter the different channels in the task but it will not let me do it. I also need to average the 4 inputs and graph those on a separate graph also. I am using version 7.1. Can anyone help please.
(3,321 Views)
You can graph four channels on one graph by putting your data points into a cluster and then graphing them. Put the average on it's own graph. An example is enclosed, it's version 6.1, but you should be able to open it if you have any higher version.
eewonder
LV 6.1, 8.2, 8.5, 8.6 beta
Fieldpoint
DAQmx
IMAQ Vision
(3,307 Views)
Thats great stuff thanks a lot.
(3,293 Views)
