"LabVIEW load error code 3: Could not load front panel." for applications (.exe)
I can't build an application based on UDP VIs. When I try to run the .exe file created by LabVIEW, I get LabVIEW error 3.
Is there a way to get around that?
Attached is my code.
(3,324 Views)
Check out the KnowledgeBase entry entitled "LabVIEW Load Error Code 3: Could Not Load Front Panel" When Running a LabVIEW Executable, and you should be able to resolve the problem.
John
(3,318 Views)
That fixed it, thanks. 🙂
(3,300 Views)
