graph multiple x-scale time values (one absolute and one relative) at the same time?
background:
    I'm display a variety of temperature points on a graph.  currently the graph has the Relative time from start on the bottom of the graph(x-scale).  it is currently set to Relative time hh:mm.
Is there a way to set this to display both the relative and the absolute time?
(2,461 Views)
Accepted by topic author ashitakaLax
This KB says to "Right-click on the axis that you want to have multiple scales and select Duplicate Scale". Once you do that, you'll have two scales and then you can just access the Properties » Display Plots and set one scale for absolute and relative time.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(2,440 Views)
