using hex values as case statement selector
I'm trying to writie a little conversion routine that accepts a hex value (read from a TTL device) and converts that to an enum.  The hex values returned aren't sequential (i.e 0x00, 0x7E, 0xF5, 0xF0, etc).
I would like to run these values into a case statement and return the appropriate enum,  I can't seem to get the syntax right for the case selector.  Can I represent the number in hex (in the case selector), or do I have to do the conversion to base 10?  If it's possible, what is the proper syntax?
(4,586 Views)
In LV 8.20 the radix of the selector is available as a popup. Internally the representation of the number makes no difference. The representation only becomes a factor when displayed.
Lynn
(4,582 Views)
Lynn, this has been around for quite a few versions before 8.2. Very useful! 🙂
Message Edited by altenbach on 02-08-2007 09:48 AM
(4,575 Views)
Thanks, Christian. I did not recall how far back it went and did not take the time to check it.
Lynn
(4,567 Views)
Hi altenbach
I am using Labview 9.0
Has this option to select the radix gone?
I am struggling to use any of the potential solutions to this problem. If I try the putting it in as code displays the \00\A0 the \A0 does not appear in the case structure (its a blank for new line or w/e) which means the comparison fails.
Where probe 9 is in the picture is where my hex is being passed in to the substring node
Any help would be much appreciated on this
(4,054 Views)
If you were to look at the image, you would see a numeric wired up and that still has the option for hex display. A string does not.
(4,050 Views)
