graph problem
I found a bug in LabView 8 about a particular graph.
I talk to NI about it and they told me that bugg will be fix in the next version.
The bugs is about the mixed signal graph and the cursor function.
When you create a multi plot cursor, wich is quite practical, and if you save it with data inside, It corrupt your application and you canot reopen it after.
If you tri it, do it with a new VI because it's suck when you have to redo the whole VI.
Benoit
PS I have joined the example VI. Run it and save it you will see the crash when you re open it.
Benoit Séguin
Software Designer
Message 11 of 11
(508 Views)
