graph without scales in report
ritesh024 wrote:
Hi Ben,
First of all thanks alot for taking so much interest in the post.
I would like to know how can i hide the scale using the references?
i dont  have much knowledge about ActiveX, so it would be great if you could enlighten me on this.
Ritesh
Hi Ritesh,
I don't know the answer but this is what I would do if it was my challenge.
MS Office  "Help for VBA" is available if you do an advnaced install of the MS stuff. Once the "Help for VBA" is installed it should be possible to bring up the help from MS. The examples are mostly in VBA (of course) but the examples generally give a hint as to how to access the property in question.
So I can't give you the final answer but hopefully that path will lead you to a solution.
If you find the answer please update this thread to help others who find themselves tredding your path at a later date.
Just trying to help,
Ben
Message 11 of 11
(373 Views)
