gray out switch
that circle at the selector what kind of function is that ? at pin s
Message 11 of 40
(2,731 Views)
Pin S? You are talking about the '?' from the Select function?
I think you are talking about "First Call".....
Norbert
Norbert
Expert: Geometry
Message 12 of 40
(2,728 Views)
dont fibd the first call function in labv7
Message 13 of 40
(2,691 Views)
found it sry
Message 14 of 40
(2,679 Views)
made this , but the switch wont gray out
Message 15 of 40
(2,669 Views)
Hi drek,
I repeat my message #9: constants are created by right-clicking an input and selecting Create->Constant.
(Do you read our comments? Do you understand them? Did you take the free online courses to learn LabVIEW basics?)
Creating an enum on your own with just one entry will be senseless, when LabVIEW expects something different here!
Message 16 of 40
(2,680 Views)
sry Gerd have to learn much , like this than, but does not work stays always on 0
Message 17 of 40
(2,668 Views)
Hi Drek,
repeating again: create the constant by right-clicking the property node input. RIGHT-CLICK! CONTEXT MENU!
If you insist on creating an constant on your own you should read the context help of the property node to create the correct constant…
Message 18 of 40
(2,655 Views)
i know how to create a constant but dont know what you are saying 😞 sry have to learn
Message 19 of 40
(2,645 Views)
Hi drek,
how did you create this constant "0"? My LV2011 shows a coercion dot for that property node input…
Did you read the context help as suggested before? Do you know what happens when you write a zero into this property?
sry have to learn
Reading the (context) help might be a good starting point…
Message 20 of 40
(2,636 Views)
