gray out switch
Can you live with HIdden?
Message 21 of 40
(2,660 Views)
OOoo. Found it. Right click Boolean. Create Reference. Click wire output and add property node. Choose: Disabled. Right click on property node Disabled input to add a constant. You get an enum. Your choices are: Enabled, Disabled, Disabled and Grayed Out.
Message 22 of 40
(2,658 Views)
Hi Regulator,
you found within minutes what Drek is searching for hours… 😞
Message 23 of 40
(2,643 Views)
pfff not for hours this is what a got 🙂
the right cick on property node disabled input to add a constant dont find that
you can laugh 🙂
Message 24 of 40
(2,624 Views)
Hi drek,
- move the mouse on the input of the "disabled" property node
- press the right mouse button
- a menu pops up: that's the so-called context menu
- select "Create" in this menu: a submenu pops up
- select "Constant"
Wow, an enum constant is magically created in the BD - of the correct datatype. Now select the enum item you want to use…
pfff not for hours
I told you a day ago to use the context menu, so you aren't able for such basic stuff for 24 hours…
This isn't even basic LabVIEW stuff, this is basic (Windows) computer usage. You should know all this before you start to use LabVIEW (or any other program).
Message 25 of 40
(2,614 Views)
getting nervous 🙂 if i right click and create constant i see a bleu square where you can put 1... in but not an enum constant
Message 26 of 40
(2,603 Views)
Hi drek,
you are on LV7 - that's the price you pay for your outdated LabVIEW version.
As also suggested before: read the context help for this property, it explains it all…
To put it in just 4 letters: "R T F M"… 😄
Message 27 of 40
(2,586 Views)
thx 🙂
Message 28 of 40
(2,579 Views)
Any luck yet?
Message 29 of 40
(2,572 Views)
nope Gerd says its a labv7 problem i quess dont know, need do look for anonther solution Smiley Frustrated
Message 30 of 40
(2,568 Views)
