graying out selections
The NewVal has the exact same representation as the control. If yours is not green, then you did not create an event for a Boolean.
Message 11 of 12
(402 Views)
elset191,
Thanks for the help. My initial problem of getting the green NewVal was that I created that case of the Event Structure in reference to the radio buttons. I switched it over to the Stop/Disable/Boolean button, and everything worked out. Hopefully I can utilize this ability to gray out buttons in my code.
Thanks again.
Message 12 of 12
(384 Views)
