guitar effects processor
Do you use line input for your guitar?
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 21 of 28
(2,332 Views)
im using a cable to connect the guitar to the laptop if thats what you mean
Message 22 of 28
(2,329 Views)
It could be that your soundcard is using the microphone gain setting. If your guitar has a line level output it would saturate the soundcard input stage, and you will get no sound output. You will find the settings I am talking about in the control panel.
Message 23 of 28
(2,308 Views)
ok I'll try that but when i tried the guitar on two similar labview examples the simultaneous sound i/o and the continuous sound input it worked fine
Message 24 of 28
(2,302 Views)
hi coq rouge would you have any idea how to go about making a simple guitar tuner
Message 25 of 28
(2,279 Views)
How does a guitar tuner work;) Do you want use the sound card as a reference signal? or something else
Message 26 of 28
(2,270 Views)
hi coq rouge sorry for taking do long to get back to you i just wanted to do a simple tuner which will compare the input signal of the guitar with signals of the six strings store in its memory, also regarding the processor i am doing when i go to add the effects to the guitar signal nothing is happening its just sort of skipping any idea why? when i simulated a signal and added the effects they worked fine is it something to do with the matlab code i am using maybe?
Message 27 of 28
(2,234 Views)
Do you know this thread?
Greetings from Germany
Henrik
LV since v3.1
Message 28 of 28
(2,182 Views)
