hOW CAN I MODEL A TANK IN LABVIEW
I WANT TOIMPLEMENT  a pid CONTROLLER FOR A TANK . i WANT TO KNOW HOW TO MODEL A GIVEN TANK IN LABVIEW PLZ HELP ME ......
Message 1 of 12
(7,921 Views)
(You should hav your keyboard repaired, something is wrong with the caps-lock key. Did you ever spill sugary soda on it?)
The numeric palette has a tank indicator, so that's a good start. Obvously, to model a PID controller, you need much more than a tank. I assume the controller should e.g. regulate input or output valves to keep the level constant.
Your question is not clear at all. Do you have problem with the mathematical model itself or do you only have problems implementing it in LabVIEW?
Message 2 of 12
(7,911 Views)
Thank for your reply.
i have modeled in mathematically i got the transfer function in mathematical form . My probelm is that how i can implement it  in the Labview and how to use pid controller for  given tank. pLz help me
Regards
lenin
Message 3 of 12
(7,906 Views)
There are several examples of PID control and simulated feedback that ship with the PID toolkit, I would start there.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 4 of 12
(7,886 Views)
It's Monday morning and this is the first thing to pop into my mind after reading the subject line.
Jim
Message 5 of 12
(7,856 Views)
Accepted by topic author FSK
If you have the Control Design and Simulation Model, we already have fully functional examples on this subject. Please open the example finder and go to "Control and Simulation >> Case Studies >> Process Control >> Horizontal cylinder and tank with level control". or just open directly from the file system:
C:\Program Files\National Instruments\LabVIEW 2011\examples\Control and Simulation\Case Studies\Process Control\Horizontal Cylinder\horizontal cylinder nonlinear tank with level control.vi
Now, notice that this is a "horizontal cylinder tank. If you have a typical tank, than you should have to modify the equation that is solving.
Hope this helps
Barp - Control, Simulation, RTT and HIL - National Instruments
Message 6 of 12
(7,840 Views)
Message 7 of 12
(7,813 Views)
Hi BARPI
    thanks for the reply .  Iam trying to make the model out from that.  My tank having  a shape of rectangular prism with top open.
regrds
FSK
Message 8 of 12
(7,789 Views)
Hi Barpi , Rest of all and NI Control system and simulation group
I  Have taken the model from the Nonlinear water tank and redesigned according my model. I got the result of the siso water tank with PID controll
THanks for the help....
regards
FSK
Message 9 of 12
(7,751 Views)
how u have modelled the tank in mathematical term. Kindly let me know??
Message 10 of 12
(6,736 Views)
