handshake technique. dividing the GUI
Good Morning,
I was working on my VI for a while and with some help I reached my first goal by representing my data that i'm receiving it into intensity graph.
i'm using an Arduino UNO to read my data from sensor sheet (rows and columns 4X4).
I connected the Arduino through USB to the laptop and used VISA to read my data from VI and display it over intensity graph and 2D array.
 please check the picture attached.
what i want now is
understanding the idea of handshake between arduino and LabVIEW. (such as master and slave idea, and make the LV the master while the Arduino is the slave).
in this case i can make the LV ask the arduino to send the data when he needed not just pushing data through VISA.
my iteration takes 1.6 seconds due to the program on Arduino
second thing
how I can divide the GUI to be two windows,
  • one for displaying the data over intensity graph (representing the sensor position)
  • second one is displaying my raw data only into 2D array.
so can I divide the Front Panel to display what I want individually ?
(3,507 Views)
Accepted by topic author N.Ghrayeb
Hi N.,
1. my iteration takes 1.6 seconds due to the program on Arduino
Use a different sketch for your Arduino part: use/create a sketch that reacts only on commands of your LabVIEW master…
2. how I can divide the GUI to be two windows
Learn about producer-consumer scheme.
Or atleast use notifiers/queues to send data to a parallel running loop…
(3,490 Views)
GerdW,
thanks for your advise, now i have a VI with several subVIs
(3,422 Views)
