have qtrly updates, no originals, have SN - how do I install on a new computer?
We own two copies of the Developer Suite -
The guy who worked here before had it installed on his machine.
One othere is STILL using it
I would like to get it up on my machine for working with it -
I cannot locate the original disks.
I HAVE 4 qtrly updates. One has the serial # in it.
How can I get it loaded ?
I need a quote on an update to current revision.
Don Simmons Test Engineer R&D Encorp Inc.
(2,465 Views)
Hello Don,
I think there may be a misunderstanding on your part. The CDs that you receive as part of Developer Suite do not actually contain "updates" to a previously installed version of LabVIEW; they are stand-alone installers. Every quarterly shipment of the Developer Suite CDs contains the full version of LabVIEW, along with the included toolkits and other National Instruments software.
In other words, if you have any set of Developer Suite CDs, you can start a new install of LabVIEW et al. immediately. You don't need any so-called "original" CDs.
Good luck!
Mike N.
(2,458 Views)
